Forums Cadillac présentations & entraide - Tous modèles + Saab
Caddy Cadillac Seville STS 1999 Codes DTC original anglais
Sujet: Caddy Cadillac Seville STS 1999 Codes DTC original anglais (Lu 5000 fois)
Cadillac
23 Août 2020 à 12:42:09 »
Cadillac Seville STS 1999 Diagnostic Trouble Codes & Meanings CODES DTC original en anglais ...
Liste codes défauts standards DTC:
C = CHÂSSIS | B = BODY [Carrosserie] | U= User network | P = Powertrain [Groupe motopropulseur]
Sujet fermé
- Pour toutes questions, merci d'ouvrir un nouveau Topic dans la section adéquate ... Merci
Général codes défauts DTC CHASSIS, BODY, User Network, Powertrain
RECHERCHE ACCÉLÉRÉE DE VOTRE CODE
- Les touches Windows fonctionnent parfaitement
Ctrl F
Codes B - BODY
DTC B0530 Fuel Level Sensor Stuck
DTC B0532 Fuel Sensor Shorted To Ground or Open
DTC B0533 Fuel Sensor Feedback Shorted High
DTC B1000 Communication Errors
DTC B1000 RFA Internal Fault (Self Test Failed)
DTC B1004 Keep Alive Memory (KAM)
DTC B1004 Loss of Keep Alive Memory (KAM)
DTC B1007 BCM Internal Memory Malfunction
DTC B1007 EEPROM Write Error
DTC B1009 BCM Internal Memory Malfunction
DTC B1009 EEPROM Checksum Error
DTC B1115 Passenger Deploy. Loop Resistance High
DTC B1116 Passenger Deploy. Loop Resistance Low
DTC B1117 Passenger Deployment Loop Open
DTC B1121 Driver Deployment Loop Resistance High
DTC B1122 Driver Deployment Loop Resistance Low
DTC B1124 Driver/Pass. Deploy. Loop Short to GND
DTC B1125 Driver/Pass Deploy Loop Short to Voltage
DTC B1126 Driver Deployment Loop Open
DTC B1131 Pass. Pretensioner Loop Resistance High
DTC B1132 Pass. Pretensioner Loop Resistance Low
DTC B1134 Passenger Pretensioner Loop Open
DTC B1141 Driver Pretensioner Loop Resistance High
DTC B1142 Driver Pretens. Deploy. Loop Res. Low
DTC B1144 Driver/Pass Pretens. Loop Short to GND
DTC B1145 Driver/Pass Pretens. Loop Short to Volt
DTC B1146 Driver Pretensioner Loop Open
DTC B1147 Driver Side Air Bag System Malfunction
DTC B1148 Pass. Side Air Bag System Malfunction
DTC B1151 Deployment Commanded - Frontal
DTC B1152 Data Area Full
DTC B1153 Deployment Commanded w/Loop Malfunction
DTC B1155 SDM Calibration Mismatch
DTC B1159 Loss of Serial Data-Key Not Received
DTC B1160 Loss of Serial Data - VIN Not Received
DTC B1161 Lamp Circuit Failure
DTC B1163 Loss of Serial Data-No Lamp Response
DTC B1171 Internal SDM Failure
DTC B1310 Ambient Air Temperature Sensor Failure
DTC B1317 In Car Air Temperature Sensor
DTC B1318 LH Sun Load Sensor Fault
DTC B1321 A/C Low Side Temperature Sensor Fault
DTC B1324 A/C Refrigerant Overpressure
DTC B1327 Battery/Source Voltage Low
DTC B1327 Device Power #1 (Low Current #1) Circuit Low
DTC B1328 Battery/Source Voltage High
DTC B1328 Device Power #1 (Low Current #1) Circuit High
DTC B1328 RH Sun Load Sensor Fault
DTC B1330 Left A/C Discharge Sensor Fault
DTC B1331 Right A/C Discharge Sensor Fault
DTC B1332 Left Heater Discharge Sensor Fault
DTC B1333 Right Heater Discharge Sensor Fault
DTC B1340 Air Mix Door One Movement Fault
DTC B1341 Air Mix Door Two Movement Fault
DTC B1343 Air Inlet Door Movement Fault
DTC B1344 HTR/DEF/AC Door Movement Fault
DTC B1390 Battery Voltage Sense Failure
DTC B1396 Device Voltage Reference Output 1 Circuit Range Performance
DTC B1399 Loss of KDD Main Control Head
DTC B1556 IPC EEPROM Odo/Configuration Error
DTC B1652 Loss of Keep Alive Memory (KAM)
DTC B1656 EEPROM Write Error
DTC B1658 EEPROM Checksum Error
DTC B1698 Mirror Switch L Up Input Stuck High
DTC B1703 Mirror Switch L Down Input Stuck High
DTC B1708 Mirror Switch R Up Input Stuck High
DTC B1713 Mirror Switch R Down Input Stuck High
DTC B1718 Power Fold Switch Stuck High
DTC B1735 Driver Seat Front Up Switch CKT Malf
DTC B1740 Driver Seat Front Down Switch CKT Malf
DTC B1745 Driver Seat Rear Up Switch CKT Malf
DTC B1750 Driver Seat Rear Down Switch CKT Malf
DTC B1755 Driver Seat Asm Forward Switch CKT Malf
DTC B1760 CD Changer Not Responding
DTC B1760 Driver Seat Asm Rearward Switch CKT Malf
DTC B1780 Theft Lock Enabled
DTC B1805 Ignition Switch Problem
DTC B1815 Driver Recline Forward Switch CKT Malf
DTC B1820 Driver Recline Rearward Switch CKT Malf
DTC B1825 Driver Recline Sensor CKT Malfunction
DTC B1830 Driver Lumbar Forward Switch CKT Malf
DTC B1835 Driver Lumbar Rearward Switch CKT Malf
DTC B1840 Driver Lumbar Up Switch CKT Malf
DTC B1845 Driver Lumbar Down Switch CKT Malf
DTC B1850 Driver Lumbar Horiz Sensor CKT Malf
DTC B1860 Driver Lumbar Vert Sensor CKT Malf
DTC B1870 Driver Belt Tower Up Switch CKT Malf
DTC B1875 Driver Belt Tower Down Sw CKT Malf
DTC B1900 Driver Belt Tower Vert Sen CKT Malf
DTC B1981 Battery Voltage Low
DTC B1982 Device Power 1 Circuit High
DTC B1982 Source/Battery Voltage High
DTC B1983 Device Power 1 Circuit Low
DTC B1983 Source/Battery Voltage Low
DTC B2175 Tilt/Telescope Module Manual Switch Fail
DTC B2200 LF Window Switch Stuck in Up Position
DTC B2201 LF Window Switch Stuck in Down Position
DTC B2202 RF Window Switch Stuck in Up Position
DTC B2203 RF Window Switch Stuck in Down Position
DTC B2204 LR Window Switch Stuck in Up Position
DTC B2205 LR Window Switch Stuck in Down Position
DTC B2206 RR Window Switch Stuck in Up Position
DTC B2207 RR Window Switch Stuck in Down Position
DTC B2212 RF Switch on LF Door Stuck Up Position
DTC B2213 RF Switch on LF Door Stuck Down Position
DTC B2214 LR Switch on LF Door Stuck Up Position
DTC B2215 LR Switch on LF Door Stuck Down Position
DTC B2216 RR Switch on LF Door Stuck Up Position
DTC B2217 RR Switch on LF Door Stuck Down Position
DTC B2220 LF Door Lock/Unlock Switch Stuck in Lock
DTC B2221 LF Door Lock/Unlock Switch Stuck UnLock
DTC B2222 RF Door Lock/Unlock Switch Stuck in Lock
DTC B2223 RF Door Lock/Unlock Switch Stuck UnLock
DTC B2224 LR Door Lock/Unlock Switch Stuck in Lock
DTC B2226 RR Door Lock/Unlock Switch Stuck in Lock
DTC B2240 Memory 1 Switch Failed
DTC B2241 Memory 2 Switch Failed
DTC B2242 Memory Exit Switch Failed
DTC B2243 Memory Set Switch Failed
DTC B2310 Hand Set Failure
DTC B2311 TRU Failure
DTC B2312 Software Failure
DTC B2355 Driver Front Vertical Sensor Malf
DTC B2365 Driver Rear Vertical Sensor Malf
DTC B2375 Driver Seat Asm Horiz Sensor CKT Malf
DTC B2419 Twilight Photocell Circuit Problem
DTC B2420 Twilight Delay Pot Failure
DTC B2422 Interior Lamp Rheostat Failure
DTC B2460 Navigation Antenna Selector Circuit High Current
DTC B2461 Navigation ECU Synchronous Signal Error
DTC B2462 GPS Signal Error
DTC B2463 Navigation CD Player - No Disk
DTC B2464 Navigation CD Player - Decoding Error
DTC B2465 Navigation CD Player - Data Error
DTC B2468 Navigation Display ECU Internal Error
DTC B2510 Steering Wheel Controls HVAC Key Stuck
DTC B2511 Steering Wheel Controls Conv Key Stuck
DTC B2512 Strng Wheel Controls Illegal A/D Values
DTC B2734 Coded Key Controller Memory Failure
DTC B2853 Telescope Forward Switch Circuit Malfunction
DTC B2858 Telescope Rearward Switch Circuit Malfunction
DTC B2860 Telescope Position Sensor Range
DTC B2862 Telescope Position Sensor Low
DTC B2873 Tilt Up Switch Circuit Malfunction
DTC B2878 Tilt Down Switch Circuit Malfunction
DTC B2880 Tilt Position Sensor Range
DTC B2882 Tilt Position Sensor Low
DTC B2891 Tilt/Telescope Motor Over Current
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2955 Security System Sensor Data CKT Malf
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B3028 Starter Relay Interface Short to Ground
DTC B3029 Starter Relay Interface Open/Short to B+
DTC B3031 Key Decoder Device in Assem Learn Mode
DTC B3055 Key Not Present
DTC B3108 Transmitter Synchronization Failure
DTC B3203 Rear Window Lockout Switch Stuck High
DTC B3282 Pass. Door Express Down Shorted to GND
DTC B3287 LR Door Express Down Shorted to GND
DTC B3292 RR Door Express Down Shorted to GND
DTC B3467 Driver Door Express Down Shorted to GND
DTC B3472 Pass. Door Express Down Shorted to GND
DTC B3477 LR Door Express Down Shorted to GND
DTC B3482 RR Door Express Down Shorted to GND
Codes C - CHÂSSIS
DTC C1211 ABS Indicator Lamp Circuit Malfunction
DTC C1214 Solenoid Valve Relay Contact or Coil Circuit Open
DTC C1217 Pump Motor Relay Contact Circuit Open
DTC C1221 LF Wheel Speed Sensor Input Signal is 0
DTC C1222 RF Wheel Speed Sensor Input Signal is 0
DTC C1223 LR Wheel Speed Sensor Input Signal is 0
DTC C1224 RR Wheel Speed Sensor Input Signal is 0
DTC C1225 LF Excessive Wheel Speed Variation
DTC C1226 RF Excessive Wheel Speed Variation
DTC C1227 LR Excessive Wheel Speed Variation
DTC C1228 RR Excessive Wheel Speed Variation
DTC C1232 LF Wheel Speed Circuit Open or Shorted
DTC C1233 RF Wheel Speed Circuit Open or Shorted
DTC C1234 LR Wheel Speed Circuit Open or Shorted
DTC C1235 RR Wheel Speed Circuit Open or Shorted
DTC C1236 Low System Supply Voltage
DTC C1237 High System Supply Voltage
DTC C1238 Brake Thermal Model Exceeded
DTC C1241 Magnasteer Malfunction
DTC C1242 Pump Motor Circuit Open
DTC C1243 BPMV Pump Motor Stalled
DTC C1252 ICCS2 Data Link Left Malfunction
DTC C1253 ICCS2 Data Link Right Malfunction
DTC C1255 EBTCM Internal Malfunction
DTC C1256 EBCM Internal Malfunction
DTC C1261 LF Inlet Valve Solenoid Malfunction
DTC C1262 LF Outlet Valve Solenoid Malfunction
DTC C1263 RF Inlet Valve Solenoid Malfunction
DTC C1264 RF Outlet Valve Solenoid Malfunction
DTC C1265 LR Inlet Valve Solenoid Malfunction
DTC C1266 LR Outlet Valve Solenoid Malfunction
DTC C1267 RR Inlet Valve Solenoid Malfunction
DTC C1268 RR Outlet Valve Solenoid Malfunction
DTC C1271 LF TCS Master Cylinder Isolation Valve Malfunction
DTC C1272 LF TCS Prime Valve Malfunction
DTC C1273 RF TCS Master Cylinder Isolation Valve Malfunction
DTC C1274 RF TCS Prime Valve Malfunction
DTC C1276 Delivered Torque Signal Circuit Malfunction
DTC C1277 Requested Torque Signal Circuit Malfunction
DTC C1278 TCS Temporarily Inhibited By PCM
DTC C1281 Stabilitrak Sensors Uncorrelated
DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction
DTC C1283 Excessive Time to Center Steering
DTC C1284 Lateral Accelerometer Sensor Self Test Malfunction
DTC C1285 Lateral Accelerometer Sensor Circuit Malfunction
DTC C1286 Steering/Lateral Accelerometer Sensor Bias Malfunction
DTC C1287 Steering Sensor Rate Malfunction
DTC C1288 Steering Sensor Circuit Malfunction
DTC C1291 Open Brake Lamp Switch Contacts During Deceleration
DTC C1294 Brake Lamp Switch Circuit Always Active
DTC C1295 Brake Lamp Switch Circuit Open
DTC C1298 PCM Class 2 Serial Data Link Malfunction
DTC C1326 Battery Out of Range
DTC C1650 RSS Control Module Fault
DTC C1658 RSS Control Module Calibration Fault
DTC C1710 LF Damper Actuator Short CKT to Battery
DTC C1711 LF Damper Actuator Short CKT to Ground
DTC C1712 LF Damper Actuator Open CKT
DTC C1715 RF Damper Actuator Short CKT to Battery
DTC C1716 RF Damper Actuator Short CKT to Ground
DTC C1717 RF Damper Actuator Open CKT
DTC C1720 LR Damper Actuator Short CKT to Battery
DTC C1721 LR Damper Actuator Short CKT to Ground
DTC C1722 LR Damper Actuator Open CKT
DTC C1725 RR Damper Actuator Short CKT to Battery
DTC C1726 RR Damper Actuator Short CKT to Ground
DTC C1727 RR Damper Actuator Open CKT
DTC C1735 Compressor Relay Short to Battery
DTC C1736 Compressor Relay Short to GND/Open CKT
DTC C1737 Exhaust Solenoid Valve Short to Battery
DTC C1738 Exhaust Solenoid Valve Short to GND
DTC C1743 Speed Signal Fault
DTC C1744 Lift/Dive Signal Discrete Fault
DTC C1760 LF Position Sensor Input Fault
DTC C1761 RF Position Sensor Input Fault
DTC C1762 LR Position Sensor Input Fault
DTC C1763 RR Position Sensor Input Fault
DTC C1768 Position Sensor Supply Fault
DTC C1780 Loss of Steering Position Signal
DTC C1782 ICCS2 DL Left Output Short CKT to Bat
DTC C1783 ICCS2 DL Left Output Short CKT to GND
DTC C1784 ICCS2 DL Right Output Short CKT to Bat
DTC C1785 ICCS2 DL Right Output Short CKT to GND
DTC C1786 Damper Control Relay Fault
DTC C1787 Damper Control Relay Short to GND
DTC C1788 Damper Control Relay Short to Bat
Codes P - POWERTRAIN
DTC P0101 Mass Air Flow (MAF) Sensor Performance
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0105 MAP Sensor Circuit Insufficient Activity
DTC P0106 Manifold Absolute Pressure (MAP) System Performance
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0111 Intake Air Temperature (IAT) Sensor Performance
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0116 Engine Coolant Temperature (ECT) Sensor Performance
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0120 TP System Performance
DTC P0121 TP Sensor Circuit Insufficient Activity
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
DTC P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
DTC P0133 HO2S Slow Response Bank 1 Sensor 1
DTC P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
DTC P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3
DTC P0144 HO2S Circuit High Voltage Bank 1 Sensor 3
DTC P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
DTC P0147 HO2S Heater Performance Bank 1 Sensor 3
DTC P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
DTC P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
DTC P0153 HO2S Slow Response Bank 2 Sensor 1
DTC P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
DTC P0171 Fuel Trim System Lean Bank 1
DTC P0172 Fuel Trim System Rich Bank 1
DTC P0174 Fuel Trim System Lean Bank 2
DTC P0175 Fuel Trim System Rich Bank 2
DTC P0201 Injector 1 Control Circuit
DTC P0202 Injector 2 Control Circuit
DTC P0203 Injector 3 Control Circuit
DTC P0204 Injector 4 Control Circuit
DTC P0205 Injector 5 Control Circuit
DTC P0206 Injector 6 Control Circuit
DTC P0207 Injector 7 Control Circuit
DTC P0208 Injector 8 Control Circuit
DTC P0218 Transmission Fluid Overtemperature
DTC P0231 Fuel Pump Feedback Circuit Low Voltage
DTC P0232 Fuel Pump Feedback Circuit High Voltage
DTC P0300 Engine Misfire Detected
DTC P0322 IC Module 4X Reference CKT No Frequency
DTC P0325 Knock Sensor Module Performance
DTC P0326 Knock Sensor CKT Excessive Spark Retard
DTC P0327 Knock Sensor Circuit Low Voltage
DTC P0340 IC Module Cam Reference CKT No Frequency
DTC P0371 IC 24X Reference CKT Too Many Pulses
DTC P0372 IC 24X Reference Circuit Missing Pulses
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0420 Catalyst System Low Efficiency
DTC P0440 Evaporative Emission (EVAP) System
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0461 Fuel Level Sensor Performance
DTC P0462 Fuel Level Sensor Circuit Low Voltage
DTC P0463 Fuel Level Sensor Circuit High Voltage
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506 Idle Speed Low
DTC P0507 Idle Speed High
DTC P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
DTC P0533 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
DTC P0550 Power Steering Pressure (PSP) Switch Circuit
DTC P0560 System Voltage
DTC P0563 System Voltage High
DTC P0601Control Module Read Only Memory (ROM)
DTC P0602 Control Module Not Programmed
DTC P0603 Control Module Long Term Memory Reset
DTC P0606 Control Module Internal Performance
DTC P0711 TFT Sensor Circuit Range/Performance
DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0716 Input Speed Sensor Circuit Intermittent
DTC P0717 Input Speed Sensor Circuit Low Input
DTC P0719 Brake Switch Circuit Low Input
DTC P0724 Brake Switch Circuit High Input
DTC P0730 Incorrect Gear Ratio
DTC P0741 TCC System Stuck Off
DTC P0742 TCC System Stuck On
DTC P0748 Pressure Control Solenoid Circuit Electrical
DTC P0751 1-2 Shift Solenoid Valve Performance
DTC P0753 1-2 Shift Solenoid Circuit Electrical
DTC P0756 2-3 Shift Solenoid Valve Performance
DTC P0758 2-3 Shift Solenoid Circuit Electrical
DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1108 BARO to MAP Sensor Comparison Too High
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1133 HO2S Insufficient Switching Bank 1 Sensor 1
DTC P1134 HO2S Transition Time Ratio Bank 1 Sensor 1
DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
DTC P1154 HO2S Transition Time Ratio Bank 2 Sensor 1
DTC P1189 Engine Oil Pressure (EOP) Switch Circuit
DTC P1258 Engine Coolant Overtemperature - Protection Mode Active
DTC P1320 IC 4X Reference Circuit Intermittent
DTC P1323 IC 24X Reference Circuit Low Frequency
DTC P1350 Ignition Control System
DTC P1370 IC 4X Reference Circuit Too Many Pulses
DTC P1371 IC 4X Reference Circuit Too Few Pulses
DTC P1375 IC 24X Reference Circuit High Voltage
DTC P1376 Ignition Ground Circuit
DTC P1377 IC Cam Pulse To 4X Reference Pulse
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1508 Idle Speed Low - Idle Air Control (IAC) System Not Responding
DTC P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding
DTC P1520 Transmission Range Switch Circuit
DTC P1524 Throttle Closed Position Performance
DTC P1527 Transmission Range to Pressure Switch Correlation
DTC P1554 Cruise Control Feedback Circuit
DTC P1560 Transaxle Not in Drive - Cruise Control Disabled
DTC P1564 Vehicle Acceleration Too High - Cruise Control Disabled
DTC P1566 Engine RPM Too High - Cruise Control Disabled
DTC P1567 Active Banking Control Active - Cruise Control Disabled
DTC P1570 Traction Control Active - Cruise Control Disabled
DTC P1571 Traction Control Torque Request Circuit
DTC P1574 Stoplamp Switch Circuit
DTC P1575 Extended Travel Brake Switch Circuit
DTC P1579 P/N to D/R at High Throttle Angle - Power Reduction Mode Active
DTC P1599 Engine Stall or Near Stall Detected
DTC P1602 Loss of EBTCM Serial Data
DTC P1603 Loss of SDM Serial Data
DTC P1604 Loss of IPC Serial Data
DTC P1605 Loss of HVAC Serial Data
DTC P1610 Loss of PZM Serial Data
DTC P1611 Loss of CVRTD Serial Data
DTC P1612 Loss of IPM Serial Data
DTC P1613 Loss of DIM Serial Data
DTC P1614 Loss of RIM Serial Data
DTC P1615 Loss of VTD Serial Data
DTC P1617 Engine Oil Level Switch Circuit
DTC P1621 Control Module Long Term Memory Performance
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
DTC P1630 Theft Deterrent Learn Mode Active
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1632 Theft Deterrent Fuel Disable Signal Received
DTC P1633 Ignition 0 Switch Circuit
DTC P1634 Ignition 1 Switch Circuit
DTC P1637 Generator L-Terminal Circuit
DTC P1638 Generator F-Terminal Circuit
DTC P1640 Driver-1-Input High Voltage
DTC P1641 Malfunction Indicator Lamp (MIL) Control Circuit
DTC P1642 Vehicle Speed Output Circuit
DTC P1644 Traction Control Delivered Torque Output Circuit
DTC P1645 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P1646 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P1650 Control Module Output B Circuit
DTC P1652 Powertrain Induced Chassis Pitch Output Circuit
DTC P1654 Cruise Control Inhibit Output Circuit
DTC P1660 Cooling Fan Control Circuits
DTC P1810 TFP Valve Position Switch Circuit
DTC P1811 Maximum Adapt and Long Shift
DTC P1814 Torque Converter Overstressed
DTC P1860 TCC PWM Solenoid Circuit Electrical DTC Table
DTC U1016 Loss of Communications with PCM
DTC U1040 Loss of Class 2 Communications with ABS
DTC U1056 Loss of Communications with RSS
DTC U1064 Loss of Communications with DIM
DTC U1065 Loss of Communications with IPM
DTC U1066 Loss of Communications with RIM
DTC U1088 Loss of Communications with SDM
DTC U1096 Loss of Communications with IPC
DTC U1128 Loss of Communications with IRC
DTC U1129 Loss of Communications with AMP
DTC U1144 Loss of Communications with PHN
DTC U1160 Loss of Communications with DDM
DTC U1161 Loss of PASS Door Module SBI
DTC U1162 Loss of Rear Driver Door Module SBI
DTC U1163 Loss of Rear PASS Door Module SBI
DTC U1166 Loss of Communications with SCM
DTC U1170 Loss of Driver Door Switch SBI
DTC U1192 Loss of Communications with VTD
DTC U1255 Class 2 Initialization Error
DTC U1300 Class 2 Short to Ground
DTC U1301 Class 2 Short to Battery
Sujet fermé
Lien très intéressant
Reading the Cadillac Onboard Diagnostic Codes * Lecture des codes de diagnostic à bord de Cadillac
[Source des codes DTC]
Cherche à louer maison / Besançon +/- 20km
codes dtc original anglais
special caddy 1999
