Auteur Sujet: How to Play Tantra K¹³ in window mode ... it's easy :)  (Lu 3874 fois)
« le: 11 Septembre 2010 à 11:50:31 »
How to Play Tantra K¹³ in window mode: Resolution & play in window mode | HTStartup.cfg | windowed mode
SOLUTION 1:
Example if Native is: 1920x1080x32
Choose for example the setting: 1600x900x32
[in this case, adjustments provided for screen size of 27 " ] (To you to do some tests.)
Then press Alt + Enter ... The result is shown below :)
SOLUTION 2:
Game resolution and play in window mode
1 - You open the directory or the game Tantra k13 is installed.
2 - You open the directory / folder system.
3 - Find and then edit the file HTStartup.cfg / With Notepad or another simple text editor
Choose your option:
windowed = false ------ for Full Screen
windowed = true  ------ for windowed mode
Save and close
Create a topic, post images, videos, everything is free
Just register here (English, Spanish, French,)
